Хотячки на Київфест(Вектор, Зіп, Неомега)
Так, список, що є з Вектора. Про ціни пишіть в приват, бо треба переводити по курсу.
    1/72 двигатели
72-001    Bristol Mercury/Pegasus  Alfa Romeo 126RC43
72-002    Wright R-2600
72-003    Gnome-Rhone GR-14K/N  M-85/87/88
72-004    P&W R-1830
72-005    P&W R-2800 A/B (early)
72-006    P&W R-2800 C (late)
72-007    Wright R-1820G (mid.)
72-008    Bristol Hercules
72-009    BMW-132
72-010    Bramo-323 "Fafnir"
72-011    Nakajima Nk1F Sakae-21/Ha-115
72-012    Nakajima Nk9 Homare/Ha-45
72-013    Mitsubishi Mk4 Kinsei/Mk8 Kasei   Ha-32/Ha-101/Ha-112
72-014    Wright R-1820G (late)
    1/48 двигатели
48-001    Bristol Mercury
48-002    Shvetsov M-11
48-003    P&W R-2800 A/B (early)
48-004    P&W R-2800 C (late)
48-005    Wright R-1820G (mid) Shvetsov M-62/M-63
48-006    P&W R-1830
48-007    P&W R-1830-86
48-008    Bristol Pegasus/Alfa Romeo 126RC34
48-009    Fiat A-74
48-010    Wright R-2600
48-011    BMW-132
48-012    Clerget 9
48-013    Gnome 9 Monosoupape
48-014    LeRhone 110-120 h.p.     Oberursel Ur. II
48-015    Nakajima Nk1F Sakae-21/Ha-115
48-016    Nakajima Nk9 Homare/Ha-45
48-017    Mitsubishi Mk4 Kinsei/Mk8 Kasei   Ha-32/Ha-101/Ha-112
48-018    Mersedes D.III/IIIa
48-019    Nakajima Nk1B/C Sakae-11/12           Ha-25
48-020    Mitsubishi Mk2 Zuisei Ha-26/Ha-31/Ha-102
48-021    Wright R-1820-F                           Shvetsov M-25
48-022    Bristol Hercules
48-023    LeRhone 80 h.p.
48-024    Oberursel U.I
48-025    Bramo 323 Fafnir
48-026    P&W R-985
48-027    P&W R-1340
48-028    P&W R-1535
48-029    Gnome-Rhone GR-14K/N    M-85/87/88
48-030    Wright R-1820G (late)
48-031    Gnome-Rhone GR-14M4/5
    1/48 наборы
VDS48-001    Soviet WWII RS-82 rockets
VDS48-002    ShKAS machine guns
VDS48-003    Yak-9/9D fuselage (for Modelsvit kit)
VDS48006    Browning M2 0.3 Cal                    Round Perforation
VDS48007    Browning M2 0.3 Cal                  Oval Perforation
VDS48008    Browning M2 0.5 Cal Fixed
VDS48009    Browning M2 0.5 Cal Flexible
VDS48010    Browning M2 0.5 Cal Barrels
VDS48011    MG-15
VDS48012    MG-17 Barrels
VDS48013    MG-131
VDS48014    MG-81
VDS48015    MG-81Z
VDS48016    Lewis/Type 92 Japanese MG
VDS48017    Vickers-K MG
VDS48018    LaGG-3 кабина
VDS48019    P-39 ниши шасси
VDS48020    P-51D ниши шасси
VDS48022    FM-2 Correction set (HB)
VDS48023    FM-2 капот
VDS48024    FM-2 пропеллер
VDS48025    Wildcat рулевые пов-ти
VDS48026    IL-2 проп. и кок
VDS48027    Yak-7/9 проп. и кок
VDS48028    Yak-7/9 рулевые пов-ти
VDS48029    Wildcat wheels diamond
VDS48030    Wildcat wheels block
VDS48031    Wildcat wheels radial
VDS48032    P-51B/C ниши шасси
VDS48033    LaGG-3 выхлопные трубы
VDS48034    LaGG-3 лыжи/бомбодерж.
VDS48035    La-5FN кабина
VDS48036    La-5 кабина
VDS48037    La-5 рулевые пов-ти
VDS48038    La-5FN рулевые пов-ти
VDS48039    Bf109F-2 коррекция (Зв.)
VDS48040    Bf109F-2 Галланд (Звезда)
VDS48041    Hs-126 кабина (ICM)
VDS48042    Hs-126 экстерьер (ICM)
VDS48043    Hs-126 испр. фонарь (ICM)
VDS48044    P-61 двигатели и капоты
VDS48045    P-61 пропеллеры и коки
VDS48046    Hs 123A/B экстерьер
VDS48047    F-4U  капот+юбка (Tamiya)
VDS48048    FW 190A-5/8 ниши  (Hasegawa)
VDS48049    Hs 123A/B кабина
VDS48050    FW 190A-3/4 ниши  (Hasegawa)
VDS48051    FW 190A-5/8 рулевые пов. (Has.)
VDS48052    Bf109F створки радиаторов (Звезда)
VDS48053    Bf109F ФКП (Звезда)
VDS48054    He 219A-0/5 конверсия (Tamiya)
VDS48055    PV-1 Ventura пропеллеры (Revell)
VDS48056    PV-1 Ventura капоты (Revell)
VDS48057    FW 190A-5/8 кабина (Hasegawa)
VDS48058    FW 190A-8 ниши  (Tamiya)
VDS48059    Spitfire VIII/IXc ниши (Has.)
VDS48060    FW 190A-3 ниши (Tamiya)
VDS48061    Bf109G-2 Конверсия для F-4 Звезды
VDS48062    A-20 Havoc  рулевые поверхности
VDS48063    Tu-2 рулевые поверхности
VDS48067    B-24 Liberator ниши и стойки
VDS48068    Me 410 пропеллеры и коки (Менг)
VDS48069    Bf 108 Tifun пропеллер
VDS48070    Me 410 радиаторы (Менг)
VDS48072    Су-2 исправленный капот и двигатель
VDS48073    Су-2М-88Б (поздний) конверсия
VDS48074    Су-2 рулевые поверхности
VDS48075    Р-40E/N пропеллер и кок
VDS48076    Як-3 пропеллер и кок
VDS48077    Як-3 ниши шасси
VDS48078    B-24 двигатели и капоты
VDS48079    B-24/B-17 пропеллеры
VDS48080    Су-2 ниши шасси (Zvezda)
VDS48081    Re.2002 рулевые поверхности и гаргрот
VDS48082    Dornier Do 17/215 исправленный хвост (ICM)
VDS48083    Re.2002 капот двигатель и винт
VDS48084    Re.2002 ниши, стойки и щитки шасси
VDS48085    Re.2002 кабина
VDS48086    P-47N ниши шасси (Academy)
VDS48087    P-47N двигатель винт и совки выхлопов (Academy)
VDS48088    P-47N кабина (Academy)
VDS48089    P-47D исправленные борта кабины (Tamiya)
VDS48090    P-47D экстерьер (Tamiya)
VDS48091    Bf110C/D/E рулевки и короткий хвост (Dragon)
VDS48092    A-20G/J Boston/Havoc кабина пилота
VDS48093    A-20J Boston/Havoc кабина штурмана
VDS48094    Spitfire Mk.V выхлопные трубы (new Airfix kit)
VDS48095    Hurricane Mk.I выхлопные трубы (new Airfix kit)
VDS48096    P-47N исправленный пропеллер
VDS48097    Norden бомбовый прицел
VDS48098    F4U-1 "Birdcage" Corsair усиленный гаргрот
VDS48099    Ju88A-5 экстерьер (ICM)
VDS48100    He 51 экстерьер (Roden)
VDS48101    И-153 №1 капот, винт, выхлопа (ICM)
VDS48102    И-153 №2 (ICM) рулевые поверхности
VDS48103    И-153 №3 (ICM) ниши шасси и кабина
VDS48104    Ju88A-4/A-14 мотогондолы (ICM)
VDS48105    Ju88A-4/A-14 пропеллеры (ICM)
VDS48106    XF5U-1 "Flying Flapjack" колеса (Kitty Hawk)
VDS48107    P-40E/N ниши и створки шасси  с чехлами (Hasegawa)
VDS48108    P-40E/N радиаторы (Hasegawa)
VDS48109    P-40E/N рулевки (Hasegawa)
VDS48110    Bf109G-6 капоты Erla (Zvezda)
VDS48111    Bf109G-6 капоты Wnf/Mtt (Zvezda)
VDS48112    Bf109G-6/14 экстерьер (Zvezda)
    1/32 двигатели
32-001    P&W R-2800 A/B (early)
32-002    P&W R-2800 C (late)
32-003    LeRhone 110-120 h.p.     Oberursel Ur.II
32-004    Wright R-1820-F Shvetsov M-25
32-005    Wright R-1820G(mid.) Shvetsov M-62/M-63
32-006    Wright R-1820-G (late)
32-007    Bristol Hercules
32-008    P&W R-1830
32-009    P&W R-1830-86
32-010    Gnome 9 Monosoupape
32-011    Bristol Pegasus
32-012    Bristol Mercury
32-013    P&W R-1340
32-014    Clerget 9
    1/32 наборы
VDS32-001    I-16 detail set
VDS32002    Browning M2 .3 Cal Round
VDS32003    Browning M2 .3 Cal Oval
VDS32004    Browning M2 .5 Cal Fixed
VDS32005    F4B-4 detail set (Hasegawa)
VDS32006    F4U-1/1A Corsair капот (Trump)
VDS32007    Bf109F-2 исправленный радиатор (Has)
VDS32008    P-51A кабина (Hobbycraft)
VDS32010    A-36A кабина (Hobbycraft)
VDS32011    F4U-1 Corsair капот (Tamiya)
    Декали
VD-48-001    Hs-126
VD-48-002    Ла-5
VD-48-003    Ла-Ф
VD-48-004    Ла-5ФН
VD-48-005    ЛаГГ-3 1/3 серия
VD-48-006    ЛаГГ-3 29 серия
VD-48-007    ЛаГГ-3 66 серия
В 10.05.2017 at 22:50, Svarog684 сказал:
Саме на А-4  - тільки один набір, все інше на А-5. Чи я щось пропустив?
На А-4 мотогондоли й гвинти
VDS48104 й
VDS48105
Игорь, я тут подумал и решил, что если не дорого и если уважаемый джинн не будет против :) , то хочу исчо и вот этот набор
Как говорят в Финляндии - "Пригодицца..."(с) ;)
В 22.05.2017 at 18:50, base сказал:
о! ще встигну! і ось це ще пліз VDS48047    F-4U  капот+юбка (Tamiya)
Встиг. Ще година для фанатів є )))
  • 4 months later...
