AZ Model 1:72. DHC-1 Chipmunk T.10/T.30
palanbor
Варианты:
De Havilland Canada Chipmunk T.10 RAF
Item No - AZ7556
Scale - 1/72nd
De Havilland Canada Chipmunk T.20 "Foreign Users"
Item No - AZ7557
Scale - 1/72nd
DHC Chipmunk T.30 Canada
Item No - AZ7558
Scale - 1/72nd
DHC Chipmunk T.10 Lycoming engine
Item No - AZ7559
Scale - 1/72nd
